TKapi
3 years agoIntel MAX 10 FFT bad works
I am using Quartus 22.1 (the problem was in 21.1 the same). IP configuration is attached.
The first anomaly: sink_sop and sink_eop are every 128clk, but the source_sop and source_eop are ran...
Kshitij_Intel
3 years agoHi,
Can you please tap the source_valid as well because source_sop is only valid when source_valid is asserted.
Thank you
Kshitij Goel
TKapi
3 years agoHi,
thank you.
The source_valid has ever one low-puls between sink_sop and sink_eop. But low puls is not synchronously with the sink_sop/eop and not synchronously with the source_sop/eop (low puls moves slowly).
What can it do?
reset_n, sink_valid, sink_error, sink_imag, ftpts_in, inverse and source_ready are continually set...
Thank you, Tomas
