TKapi
3 years agoIntel MAX 10 FFT bad works
I am using Quartus 22.1 (the problem was in 21.1 the same). IP configuration is attached.
The first anomaly: sink_sop and sink_eop are every 128clk, but the source_sop and source_eop are ran...
TKapi
3 years agoHi,
I tried differet FFT settings and different FPGA size.
FPGA: 10M25SAE144I7G
Now, I have another, but similar, problem. The signal source_sop has double size (it takes two clocks of clk). Is it normal?
ZOOM:
What could be the cause? Has the clk signal any restrictions? My clk frequency is 390 Hz.
Thank you, Tomas
