Intel HDMI core lock times in HDMI 2.0 mode
We are using the HDMI core and we are getting very long lock times (one second or more). We are using a custom patch to mitigate the HDMI 2.0 mode no-internal-data-alignment issue which is still not properly documented in the core datasheet.
Could you please provide us with a documentation on how to align the incoming PHY data externally to the core (what is the required format) or provide us with a custom patch to lower the lock times? What is the lowest lock time we can expect of the core?
Thank you
- Deshi_Intel
Hi FIlip,
FAE Steve has helped you to file new IPS case 369276 for this issue and I have provided my reply in the IPS.
We can just communicate further using IPS case instead.
REgards,
Dlim
- FRoth
Hi Dlim,
The Intel Premier support is no longer accessible to us, that is why I had to ask Steve for assistance. Could you please post the answer here on the forum?
Thank you
Filip
- Deshi_Intel
Sure.
- Regarding HDMI 2.0 custom patch support
- Higher lock time is expected from custom patch support that’s using the bitslip mode soft logic design
- Regarding improvement on HDMI RX lock time
- Customer can consider to use PHY alignment function that’s enabled via A10 FPGA hard PCS block in A10 HDMI example design.
- The only catch is this PHY alignment function is enabled together with transceiver data rate reconfiguration function
- From A10 HDMI example design hdmi_rx_top.v file, rx_parallel_data is generated from output of transceiver RX channel (gxb_rx) then to PHY alignment block (symbol_aligner) before it’s passed to HDMI RX core (mr_hdmi_rx_core_top)
- FRoth
Perfect, thank you for the explanation.
