DZuck1
7 years agoIntel DisplayPort Example Project Fails to Generate Simulation (Quartus Pro v19.1/v19.2)
Hi, I am trying to generate the simulation HDL for the Intel DisplayPort example project for the Stratix 10. I am consistently getting the same error message (attached). I have tried changing the n...
Deshi_Intel
7 years agoHi,
This looks like a known issue in Quartus Pro v19.1 that will be fixed in future Quartus release.
Kindly confirm if you are using Windows platform to generate Display Port example design ? If yes, then I maybe able to share workaround fix to you via private message.
Else you can also use Quartus Pro Linux version as workaround.
dlim
DZuck1
7 years agoYes, I am using Windows to generate the example design.
