dsun01
Contributor
3 years agoIntel Arria 10/cyclone 10 hard ip for PCI express generate example design failed
Dear Intel Expert,
I opened a project downloaded from Intel. AN829, I have some trouble to run the simulation. the problem is being reviewed by intel.
this is a related topic buy not the same o...
- 3 years ago
Hi David,
As mentioned in the previous forum
https://community.intel.com/t5/FPGA-Intellectual-Property/AN829-simulation-ran-but-failed/m-p/1415437#M26340I am able to run full compilation based on the same .qar file provided by you (without modifying any parameter)
So do you have time to try it again?
Wincent_Intel
Wincent_Altera
3 years agoHi David,
As Idle is not recommend, So I wish to follow up with you on this case.
Do you have any further questions on this matter?
Wincent_Intel
