Intel Arria 10/cyclone 10 hard ip for PCI express generate example design failed
- 3 years ago
Hi David,
As mentioned in the previous forum
https://community.intel.com/t5/FPGA-Intellectual-Property/AN829-simulation-ran-but-failed/m-p/1415437#M26340I am able to run full compilation based on the same .qar file provided by you (without modifying any parameter)
So do you have time to try it again?
Wincent_Intel
Hi David,
Wincent_Intel
Hi Wchiah,
I don't have problem to compile it. I have trouble to run the simulation with the example testbench.
I moved forward to the "Intel® Arria® 10 or Intel® Cyclone® 10 GX Avalon® Memory-Mapped (Avalon-MM) DMA Interface for PCI Express* Solutions User Guide"
I am going to follow the guide step by step, it will take a little more time, hope it will be a little smoother than the ANs.
Thank you for help,
David
