Intel Arria 10/cyclone 10 hard ip for PCI express generate example design failed
- 3 years ago
Hi David,
As mentioned in the previous forum
https://community.intel.com/t5/FPGA-Intellectual-Property/AN829-simulation-ran-but-failed/m-p/1415437#M26340I am able to run full compilation based on the same .qar file provided by you (without modifying any parameter)
So do you have time to try it again?
Wincent_Intel
Hi David,
Nice to see you again, I have been assigned to handle both cases created by you.
Please allow me to have more time to confirm the answer before getting back to you due to limited bandwidth.
Wincent_Intel
- Wincent_Altera3 years ago
Hi David,
Wincent_Intel
- dsun013 years ago
Contributor
Hi Wchiah,
I don't have problem to compile it. I have trouble to run the simulation with the example testbench.
I moved forward to the "Intel® Arria® 10 or Intel® Cyclone® 10 GX Avalon® Memory-Mapped (Avalon-MM) DMA Interface for PCI Express* Solutions User Guide"
I am going to follow the guide step by step, it will take a little more time, hope it will be a little smoother than the ANs.
Thank you for help,
David
