Intel Arria 10 with dual-rank UDIMM EMIF
- 3 years ago
Hello Mark,
I have attached the example design in .qar file below. Please let me know if this design can fit into your board.
Please share the Report DDR as snapshot below after the compilation process.
Hello Mark,
Do you have any feedback in this thread?
Adzim
- ushermark3 years ago
Hello Adzim,
Sorry for delayed answer. I had no time to check it on previous week.
I will attach Timing Analyzer results to this message. I believe, it says the same thing that I see from EMIF Debugger. I haven't tried to use this tool before, so I might miss something from it.
The project is based on example design with modified parameters.
Also, I am pretty sure that pins are correct, because the same project with different timings in EMIF IP has been used with different memories like UDIMM 1Rx8 non-ECC, RDIMM 2Rx8 ECC etc.
Mark
