Intel Arria 10 with dual-rank UDIMM EMIF
- 3 years ago
Hello Mark,
I have attached the example design in .qar file below. Please let me know if this design can fit into your board.
Please share the Report DDR as snapshot below after the compilation process.
Hello Mark,
The Arria 10 device can support DDR4 memory device with UDIMM memory format , up to 2 DIMM per channel , up to 4 Rank topologies.
You can check the details with EMIF Spec Estimator in this link: https://www.intel.com/content/www/us/en/support/programmable/support-resources/support-centers/emif-spec-estimator.html
I can help to check the EMIF IP configuration based on the memory device datasheet.
Can you share the memory device datasheet that you are using and also some snapshots of the EMIF IP?
Thanks & Regards,
Adzim
Hello.
Currently I am using the following memories:
| Kingston | KVR26N19D8/16 | Samsung K4A8G085WE-BCWE | 16 GB | 2666 | UDIMM | 2Rx8 | Non-ECC |
| SK hynix | HMA82GU6AFR8N-UH | SK hynix H5AN8G8NAFR-UHC | 16 GB | 2400 | UDIMM | 2Rx8 | Non-ECC |
Here are manuals from memory manufacturer:
https://www.memory-distributor.com/pub/media/downloads/datasheets/K4A8Gxx5WC.pdf
https://download.datasheets.com/pdfs/2017/11/3/5/12/58/809/hyn_/manual/h5an8g6nafr-vkc.pdf
So far, I have reached pretty good marging, but it started to fail write leveling after 2nd group.
Attaching zip archive with calibration results and EMIF parameters.
