Arune34
1 year agoIntel Agilex 7 FPGA E-Tile Transceiver PHY - Parallel Data
Hi everyone, I have doubt in the parallel data interface of Intel Agilex 7 FPGA's E-Tile Transceiver PHY IP core. My design has a parallel data of 128-bit width, So I used the "Enable TX/RX double ...
Ash_R_Altera
1 year agoThe document has correct information. When double data width is enabled, the bus width will be 64 x 2 = 128. The bit mapping is also provided in the table and also other tables below that.
