14 years agoInput and Output while using Altera Simulink Blocks
Hi all; I am new to Simulink and Altera blocks. Last couple days I have been working on simulating simple projects using simulink blocks. Now I started to use Altera blocks instead of simulink but...
14 years ago --- Quote Start --- No you don't need the Signal Compiler and Testbench blocks to test your design. Have you tried using my design? Perhaps you should compare the configuration of the blocks to your blocks. --- Quote End --- Sorry about my very late reply. I had really busy couple days. I tried your design also. I attached the screenshot of my result. I really wonder if it is some kind of license related issue..... image_link (http://db.tt/rjmeuawg)
