14 years agoInput and Output while using Altera Simulink Blocks
Hi all; I am new to Simulink and Altera blocks. Last couple days I have been working on simulating simple projects using simulink blocks. Now I started to use Altera blocks instead of simulink but...
14 years agoNo you don't need the Signal Compiler and Testbench blocks to test your design.
Have you tried using my design? Perhaps you should compare the configuration of the blocks to your blocks.
