14 years agoInput and Output while using Altera Simulink Blocks
Hi all; I am new to Simulink and Altera blocks. Last couple days I have been working on simulating simple projects using simulink blocks. Now I started to use Altera blocks instead of simulink but...
14 years agoHow have you configured you Input and Output blocks?
If your constant is outputting 0.5 and your Input is set to something like unsigned integer of width 8, then it would truncate your input to 0. Similarly with your Sine block, if your amplitude is too low it may be truncated.
