dscully
3 years agoIncorrect Frame Buffer Stride Validation in VVP Frame Buffer
Hello, We believe we have discovered an issue with the VVP Frame Buffer component GUI validation for checking invalid values for Inter-buffer Stride in Quartus Pro 23.2. The documentation says the ...
- 3 years ago
David, thanks for spotting this bug, I understand it will be fixed in 23.4. Your solution looks correct.
ZH_Intel
3 years agoHi David,
Good day.
We may need more time to clarify on this.
Could you share with us your design project? also the Ip settings(video resolution)?
Thank you.
Zul
