Inconsistencies in FFT IP Core and Matlab FFT Output
- 6 years ago
Sorry for the delay. I have been performing some tests in Matlab on this. For your information, based on my understanding, Matlab FFT seems to be working with Natural data type only. I have generated a FFT instance with configuration similar to yours but set the Input Order = Natural instead of Digit Reverse. This is to further isolate the part of undoing digit reverse.
As I simulated the Matlab model using your fft_test.m, it seems like I am able to get similar peak frequency between Matlab FFT and CV FFT. I have sent the simulation zip and the screenshot to you through the Forum email for your reference.
Note that I am using CV FFT in Q17.0Std and Matlab R2015a since I only have these available in my PC.
Chee Pin
As I understand it, you seems to observe discrepancy between the FFT IP core vs Matlab built-in FFT in Matlab simulation. To ensure we are on the same page, just would like to check with you on the following:
- What is the FPGA device, Quartus version and Matlab version that you are using?
- Please share with me the FFT .ip file so that I can have better understanding of your configuration.
- Would you mind to further elaborate on the discrepancy observation when you refer to the peak? Some screenshot or illustration will be helpful.
- Would you mind to further elaborate on the detailed steps to generate the FFT IP core model for Matlab simulation? I would like to perform observation replication on my side.
- Just would like to check with you if you have had a chance to try with Modelsim simulation to see if similar discrepancy observed? This is to narrow down if it is model related issue.
- HGAEN6 years ago
Hello!
My apologies for the missing information. I am using Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition, Matlab version 9.7.0.1190202 (R2019b), and I am targeting A Cyclone V 5CSEBA6U23I7DK. I have attached a .zip with all of the IP files (including the .qip) inside.
When I run the Matlab script, I see the following:
The actual frequency should be 15.2 (from my test script).
In order to generate the FFT IP core, in my Quartus Project, I open the IP catalog, search for "FFT" and double click it. I give the core a name (test_fft_ip.qsys in this case), and set the parameters to the following:
Then I click "Generate Example Design", select the default directory and click "OK".
I have not yet tried simulating with Modelsim, I will do that now.
Thank you so much!
