14 years agoImplementation of Avalon ST-Video protocol
I try to implement a Avalon ST-Video Interface in a component inside a video and image processing chain. The chain I use (from tPad VIP Camera example) works without my component. The present processing chain is : Clocked Video Input/Color Plane Sequencer/Frame Buffer/Clipper/Scaler/Mixer/Control Synchronizer/Frame Buffer/Color Plane Sequencer/Clocked Video Input. It uses camera's frames and displays them on a screen. For now, in order to learn how use this interface, my goal is just to have with my component a delay of one cycle between the Clocked Video Input and the Color Plane Sequencer. Here is my VHDL code : --- Quote Start --- asi_in0_ready <= aso_out0_ready; process(clk) begin if clk'event and clk='1' then if asi_in0_valid='1' and aso_out0_ready='1' then aso_out0_valid <= asi_in0_valid; aso_out0_data <= asi_in0_data; aso_out0_startofpacket <= asi_in0_startofpacket; aso_out0_endofpacket <= asi_in0_endofpacket; else aso_out0_valid <= '0'; end if; end if; end process; --- Quote End --- The problem is just the first frame is displayed on the screen and after it is freezed. I don't understand what is wrong. Could someone help me? Thank you in avance,1 Reply
does your core propagate ready upstream? don't forget the video IP has a ready_latency=1
