Implement a Remote System Upgrade in FPGA fabric
Please find my response below:
[1] FPL? Do you mean PFL (Parallel Flash Loader) ?
Yes, it is Parallel Flash Loader (PFL).
[2] We will also require the 'Image Update Circuitry' functionality within our Cyclone V FPGA (wrt fig17 of the PFL Intel FPGA IP User Guide) and we will like if possible to use the 'Remote Update Intel FPGA IP' (option 1 - our preferred option BUT see below ..)
Otherwise (option 2) will have to implement our own User 'Image Update Circuitry' logic to implement this functionality. You confirmed that we can add other circuitry to implement the 'Image Update Circuitry' logic. Has anyone else implemented a similar design (option2)? Do you have any example design to suggest for the type of devices we are using ?
Yes, as stated above. User can create their own 'Image Update Circuitry' or use Intel Remote Update IP for remote updating functionality. Apologize that do we not have any example design for option 2.
[3] We are using FPP configuration mode 1Gb Flash 16 bits (instantiating an altera_paraller_flash_loader_0 ie not the version II ie altera_paraller_flash_loader_2) and will like to maintain this FPP configuration working. We instantiate the PFL IP core in the MAXV CPLD for Fast Passive Parallel (FPP) configuration and planning to use the features in the PFL IP core to perform Remote System Upgrade.
In Option1, can we use a Serial-to-Parallel conversion (S2P) to the serial output data and address of the 'Remote Update Intel FPGA IP' output serial Data/Address to generate parallel Data/Address to our parallel flash? And to use a S2P could the configuration device be a PS one or AS type from the list below of available configuration devices? I believe here it should be PS so when convert to parallel it will be still passive type. Please clarify here.
To use Remote Update IP, we need to select configuration mode in Quartus as Active Serial mode. So for this scenario, PS for configuration and AS for remote update, I would suggest to use the flash which are supported by both scheme.
You can find the list of flash devices supported by PFL IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf (Page 4)
Thank You.
Bruce
