I3C IP
As mentioned, we do not have the IP or documentation, thus you may need to rely on 3rd party IPs. For e.g I3C from MIPI:
https://www.synopsys.com/dw/ipdir.php?ds=mipi_i3c
They have replaced the name usage for master to controller and slave to target respectively.
As for your 2nd questions, I don't think the voltage is an issue, but they are others I3C specifications that need to be checked, for example dynamic switching which is a requirement for I3C, which unfortunately for Cyclone IV/V is not supported. I am not familiar with these terms nor the full I3C specification requirements.
But if you may, you may still try contact the available 3rd party IPs devs to discuss how it can work on our devices, apart from that we are unable to provide further supports.
I hope my suffice support have help you with your issue.
