14 years agoi2c from altera wiki
Hi all I've downloaded the i2c ip from altera wiki and simulated it in Nios II with ModelSim-Altera. http://www.alterawiki.com/wiki/opencores_i2c (http://www.alterawiki.com/wiki/opencor...
14 years ago --- Quote Start --- What's the voltage level on those small "1"? --- Quote End --- It's about 0.6 V. An EEPROM doesn't drive SCL. Apperently an additional driver besides the master's open drain output and the pull-up resistor is connected to the bus.
