14 years agoi2c from altera wiki
Hi all I've downloaded the i2c ip from altera wiki and simulated it in Nios II with ModelSim-Altera. http://www.alterawiki.com/wiki/opencores_i2c (http://www.alterawiki.com/wiki/opencor...
14 years agoThank FvM for your reply.
I check the signal connections from bottom module to the top module. I think the scl_o and sda_o signals in i2c_master_bit_ctrl module are actually the signals scl_pad_o and sda_pad_o in the top module "opencores_i2c". If the scl_padoen_o and sda_padoen_o are low, scl_pad_o and sda_pad_o are selected as the external output signals. So this is why I check scl_o and sda_o in my simulation.
assign scl_pad_io = scl_padoen_o ? 1'bZ : scl_pad_o;
assign sda_pad_io = sda_padoen_o ? 1'bZ : sda_pad_o;
