14 years agoi2c from altera wiki
Hi all I've downloaded the i2c ip from altera wiki and simulated it in Nios II with ModelSim-Altera. http://www.alterawiki.com/wiki/opencores_i2c (http://www.alterawiki.com/wiki/opencor...
14 years agoYou are looking at the wrong signals in your simulation. sda_o and scl_o are in fact tied to ground. The pins are controlled by the respective enable signals. Reading 2.3 external connections in the doc should clarify things,
