14 years agoI2C core issue
Hello. I want to use Wishbone I2C core from OpenCores in my Nios project. Trying to send a byte, i write 0xA2 byte to TxR and set STA and WR bits, the TIP flag asserts high and then never negates ...
14 years agoIt seem to solve the tip latching problem, but still there are some arbitration issues. The piece of schematic:
http://i41.tinypic.com/2h3a32d.png And the code:
int i2c_init(int prescaler,void* isr,int BASE,int IRQ,int IRQ_ICID){
int res=1;
IOWR_16DIRECT(BASE,OC_I2C_PRER_LO,prescaler);
if(IORD_16DIRECT(BASE,OC_I2C_PRER_LO)==prescaler){
IOWR_8DIRECT(BASE,OC_I2C_CTR,0xC0);
if(IORD_8DIRECT(BASE,OC_I2C_CTR)==0xC0){
if(alt_ic_isr_register(IRQ_ICID,IRQ,isr,NULL,NULL)==0){
res=0;
return res;
static void i2c_isr(void *context){
printf("Status register: %d\n",IORD_8DIRECT(I2C_BASE,OC_I2C_SR));
IOWR_8DIRECT(I2C_BASE,OC_I2C_CR,0x01);
int main()
if(i2c_init(PreSC,(void*)i2c_isr,I2C_BASE,I2C_IRQ,I2C_IRQ_INTERRUPT_CONTROLLER_ID)==0){
IOWR_8DIRECT(I2C_BASE,OC_I2C_TXR,0x80); //write slave address+write bit
IOWR_8DIRECT(I2C_BASE,OC_I2C_CR,0x90); //set STA, set WR
IOWR_8DIRECT(I2C_BASE,OC_I2C_TXR,0x02); //write subaddr
IOWR_8DIRECT(I2C_BASE,OC_I2C_CR,0x10); //set WR
IOWR_8DIRECT(I2C_BASE,OC_I2C_TXR,0x81); //write addr+read bit
IOWR_8DIRECT(I2C_BASE,OC_I2C_CR,0x90); //set WR, set STA
IOWR_8DIRECT(I2C_BASE,OC_I2C_CR,0x68); //set NACK, set STO, SET RD
printf("RxD=%d\n",IORD_8DIRECT(I2C_BASE,OC_I2C_RXR));
}else{
printf("I2C init fail!\n");
return 0;
} Right after i register the ISR, the arbitration lost occures (once). Then not a single acknowledgement from slave (ADV7180) proceed.
