13 years agoi2c communication with itg-3200
Hello everybody, I want to connect a 3axis digital gyroscope ITG-3200 with cyclone FPGA kit(EP1C12Q240C8) of iisc Bangalore.II have hardware setup.My board does not contain nios ii processor or ...
13 years agoYou can use the digital I/O pins for the I2C bus. The SDA pin needs to be birectional so you will probably have to use a hole 8-bit group just for this signal.
There are several ways to implement an I2C bus, with a hardware controller (there is one on Opencores) or by software using bit banging. Do you have a CPU in your project? What is it, if it isn't a NIOS?
