TSUGI
5 months agoI want to use a lot of 10GBase-R PHY on an Agilex 5 E
I want to implement a lot of 10GBase-R PHY with XGMII Interface in an Agilex 5 E-Series. I need NOT to use 10G Ethernet MAC. I found some IP Parameters in GTS PMA and FEC Direct PHY IP. Is it co...
CheepinC_altera
5 months agoHi,
Based on the screenshot alone, I don’t see any obvious anomalies. That said, it’s difficult to determine whether the configuration fully aligns with your specific use case from the screenshot alone.
I would recommend cross‑checking the configuration against your target requirements and running a functional simulation to verify that it behaves as expected for your intended application.
Please let me know if you have any concerns. Thank you.
