Jacob11
3 years agoI need a scheme to max out the DSP blocks on a Stratix 10
Hello guys,
I am working on a design to use all 3000 DSP blocks on the stratix 10 FPGA. I thought the best solution would be to instantiate this intel fixed point DSP IP as a multiplier:
https:...
- 3 years ago
SOLVED!!!!
I was assigning the output registers of each DSP block incorrectly.
What I had:
assign result1_a_r[i] = result1_a[i];
assign result1_b_r[i] = result1_b[i];What it should be:
always @(posedge clk_i) beginresult1_a_r[i] <= result1_a[i];result1_b_r[i] <= result1_b[i];endI replaced this code in each of the chained DSP blocks and now I have it running up to 3000 DSP blocks.ThanksJacob
Nurina
3 years agoHi Jacob,
What device are you targeting? Can you give the OPN number?
Also, which Quartus version are you using?
Nurina
Jacob11
3 years agoGood morning Nurina.
We are using a Stratix 10 1SM21BEU2F55E2VG on a board of our own design.
Jacob
