I need a scheme to max out the DSP blocks on a Stratix 10
- 3 years ago
SOLVED!!!!
I was assigning the output registers of each DSP block incorrectly.
What I had:
assign result1_a_r[i] = result1_a[i];
assign result1_b_r[i] = result1_b[i];What it should be:
always @(posedge clk_i) beginresult1_a_r[i] <= result1_a[i];result1_b_r[i] <= result1_b[i];endI replaced this code in each of the chained DSP blocks and now I have it running up to 3000 DSP blocks.ThanksJacob
You could leave the DSP's at top level and use virtual pin assignment to fix the I/O problem.
https://www.intel.com/content/www/us/en/docs/programmable/683641/21-3/virtual-pins.html
Nurina
- Jacob113 years ago
Hello Nurina,
The output issue is solved by this trick, but i got bottlenecked at 468 DSP blocks.
I also tried chaining a lot of DSP blocks together (output from block1 as input of block2). This also works until I reach 468 DSP blocks. Then the place and route process fails with the message:
Error(184036): Cannot place the following 57 DSP cells -- a legal placement which satisfies all the DSP requirements could not be found
Info(184037): Node "GEN_DSP_2[0].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[132].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[133].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[134].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[135].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[136].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[137].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[138].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[139].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(184037): Node "GEN_DSP_2[140].U_DSP|s10_native_fixed_point_dsp_0|fourteennm_mac_component"
Info(18798): And 47 more similar nodes (full list omitted for brevity)Here is the important parts of the updated code:
module power_test_design (input wire clk_i,output wire [NUM_DSP_BLOCKS-1:0] output0,output wire [NUM_DSP_BLOCKS-1:0] output1,output wire [NUM_DSP_BLOCKS-1:0] output2);
localparam NUM_DSP_BLOCKS = 175;wire [36:0] result0_a [NUM_DSP_BLOCKS-1:0];wire [36:0] result0_b [NUM_DSP_BLOCKS-1:0];wire [36:0] result1_a [NUM_DSP_BLOCKS-1:0];wire [36:0] result1_b [NUM_DSP_BLOCKS-1:0];wire [36:0] result2_a [NUM_DSP_BLOCKS-1:0];wire [36:0] result2_b [NUM_DSP_BLOCKS-1:0];//generate DSP chaingeneratefor (i=0; i<NUM_DSP_BLOCKS; i=i+1) begin : GEN_DSP_0
dsp_fixed U_DSP (.ay ($unsigned(ay_r)), // input, width = 18, ay.ay.by ($unsigned(by_r)), // input, width = 18, by.by.ax ($unsigned(ax_r)), // input, width = 18, ax.ax.bx ($unsigned(bx_r)), // input, width = 18, bx.bx.resulta (result0_a[i]), // output, width = 37, result0_a.result0_a.resultb (result0_b[i]), // output, width = 37, result1.result1.clk0 (clk_i), // input, width = 1, clk0.clk.clk1 (), // input, width = 1, clk1.clk not used.clk2 (), // input, width = 1, clk2.clk not used.ena (ena_r) // input, width = 3, ena.ena);assign output0[i] = result0_a[i][0];endendgenerategeneratefor (i=0; i<NUM_DSP_BLOCKS; i=i+1) begin : GEN_DSP_1
dsp_fixed U_DSP (.ay (result0_a[i][17:0]), // input, width = 18, ay.ay.by (result0_b[i][17:0]), // input, width = 18, by.by.ax (result0_a[i][17:0]), // input, width = 18, ax.ax.bx (result0_b[i][17:0]), // input, width = 18, bx.bx.resulta (result1_a[i]), // output, width = 37, result0_a.result0_a.resultb (result1_b[i]), // output, width = 37, result1.result1.clk0 (clk_i), // input, width = 1, clk0.clk.clk1 (), // input, width = 1, clk1.clk not used.clk2 (), // input, width = 1, clk2.clk not used.ena (ena_r) // input, width = 3, ena.ena);
assign output1[i] = result1_a[i][0];endendgenerate
generatefor (i=0; i<NUM_DSP_BLOCKS; i=i+1) begin : GEN_DSP_2
dsp_fixed U_DSP (.ay (result1_a[i][17:0]), // input, width = 18, ay.ay.by (result1_a[i][17:0]), // input, width = 18, by.by.ax (result1_b[i][17:0]), // input, width = 18, ax.ax.bx (result1_b[i][17:0]), // input, width = 18, bx.bx.resulta (result2_a[i]), // output, width = 37, result0_a.result0_a.resultb (result2_b[i]), // output, width = 37, result1.result1.clk0 (clk_i), // input, width = 1, clk0.clk.clk1 (), // input, width = 1, clk1.clk not used.clk2 (), // input, width = 1, clk2.clk not used.ena (ena_r) // input, width = 3, ena.ena);assign output2[i] = result2_a[i][0];endendgenerateThen for the assignment editor it looks like this:Unfortunately, I still get the error message:Error(184036): Cannot place the following 57 DSP cells -- a legal placement which satisfies all the DSP requirementscould not be foundIf I lower the "NUM_DSP_BLOCKS localparam" until the total DSP blocks are less than 468, the project successfullycompiles through to the assembler stage. If its more than 468 in total, no matter how i configure this thingI get this error message. It synthesizes fine, but fails place and route.I have tried just doing one big block of 500 DSP generates, and I have tried chaining together 20 DSP generatesthat generate only 30 each. All of it bottlenecks at 468. There is some kind of limitation here, but the error messageis not meaningful enough for me to understand.Any other ideas??Thanks,Jacob
