AdzimZM_Altera
1 year agoHi Hidetaka,
You can try to set the environment variable in your PC by adding the TBB_MALLOC_DISABLE_REPLACEMENT=1 parameter in System Variables.
Then restart your PC.
Try to replicate the issue again and share the generation log again.
Adzim
Hidetaka
1 year agoHello Adzim-san,
I added "TBB_MALLOC_DISABLE_REPLACEMENT=1" to the system environment variables you told me about, and was able to generate the Example Design without any errors.
I'm very grateful to you.
Please close this case here.
Thanks, Hidetaka.
