Hidetaka
1 year agoI am unable to generate the Cyclone VGX LPDDR2 controller IP due to an error.
I purchased a board with cyclone VGX and LPDDR2 installed. I plan to use LPDDR2 hard memory controller and nios V with this cyclone Vgx. However, when I generate the LPDDR2 controller with megawize...
AdzimZM_Altera
1 year agoHi Hidetaka,
You can try to set the environment variable in your PC by adding the TBB_MALLOC_DISABLE_REPLACEMENT=1 parameter in System Variables.
Then restart your PC.
Try to replicate the issue again and share the generation log again.
Adzim
- Hidetaka1 year ago
Hello Adzim-san,
I added "TBB_MALLOC_DISABLE_REPLACEMENT=1" to the system environment variables you told me about, and was able to generate the Example Design without any errors.
I'm very grateful to you.
Please close this case here.Thanks, Hidetaka.
