I am unable to generate the Cyclone VGX LPDDR2 controller IP due to an error.
Hi
Can you share the IP generation window here?
I want to observe the error message that you are facing.
Adzim
Hello, Adzim-san.
sstrell-san.
At first, I got the error: <./nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally>.
After that, I successfully set up wsl1 and ubuntu-18.04 on Windows 11,
and when I tried to generate LPDDR2 again, the following error message appeared.
Error: Execution of script C:/Users/user/AppData/Local/Temp/alt0222_1666408435099083815.dir/0008_LPDDR2_top2_gen/simulation/generate_sim_example_design.tcl failed
Error: Info: *******************************************************************
Error: Info: Running Quartus Prime Shell
Error: Info: Version 24.1std.0 Build 1077 03/04/2025 SC Standard Edition
- Hidetaka1 year ago
Hello, Adzim-san.
sstrell-san.When I saw the error message, the error was in the "Info: LPDDR2_top2: Generating example design" item,
so I thought maybe I just shouldn't generate the example design, so I ran it, and it was generated without any errors.
Error: Execution of script "/0008_LPDDR2_top2_gen/simulation/generate_sim_example_design.tcl" is causing an error, so I would appreciate it if you could fix this part.Regard, Hidetaka.
