ConnorSousa
4 years agoHyperlynx DDRx Batch Wizard - Channel Loss Calculation Tool
I am attempting to fill IP parameters for an Arria 10 EMIF using a DDR4 LRDIMM, so I have followed the instructions at: https://community.intel.com/t5/FPGA-Wiki/Arria-10-EMIF-Simulation...
AdzimZM_Altera
4 years agoHi Connor,
I'm using Microsoft Excel version 2202.
The is an error will popup when I running the program.
But you are able to run the example file provided that's means the software is okay.
From the EMIF Support page, the tool is only compatible with Mentor Graphic Hyperlynx Signal Integrity only.
I'm not sure about the supported version for the software.
The software version for the generated report is "Software Version: v9.2 build 1794310"
By any chance, are you able to test with this version?
Adzim
