ConnorSousa
4 years agoHyperlynx DDRx Batch Wizard - Channel Loss Calculation Tool
I am attempting to fill IP parameters for an Arria 10 EMIF using a DDR4 LRDIMM, so I have followed the instructions at: https://community.intel.com/t5/FPGA-Wiki/Arria-10-EMIF-Simulation...
AdzimZM_Altera
4 years agoHi Connor,
I have received the file and tested it.
Every time I try to run the program, the error will pop up.
Run-time error '9': Subscript out of range.
Are you see similar error like above?
Can you provide the details of the environment that you used such as the Quartus version, Hyperlynx version?
Have you successful use the channel loss calculation tool before?
Adzim
