15 years agoHP DDR2 Controller fails Calibration/Initialization
Hye all, I'm trying to get a DDR2 HP Controller running on some custom hardware, but it fails during calibration.. Target is an ArriaIIGX (EP2AGX45CU17C6), RAM is a single Micron MT47H64M1...
13 years ago --- Quote Start --- We had the very same problems and it turned out that it is the same root cause. Thanks for sharing your thoughts and solution with this issue! --- Quote End --- I agree :). Posting stuff like this is very helpful for others (like me). I just got a board back with the same problem. Apparently the .pin file will not tell you to connect VREF to 0.75V if mem_clk, but no other SSTL "inputs", are in a bank. Anyway, we found another workaround that I am attaching to this post. (BTW our design uses DDR3 not DDR2.) There must be a reason for them using the single ended buffer, so I don't think this workaround is good forever, but it is acceptable for testing your design until you get your re-worked board. Regards, Keith
