15 years agoHP DDR2 Controller fails Calibration/Initialization
Hye all, I'm trying to get a DDR2 HP Controller running on some custom hardware, but it fails during calibration.. Target is an ArriaIIGX (EP2AGX45CU17C6), RAM is a single Micron MT47H64M1...
15 years agoUpdate:
I may have found a possible error (and possible cause for problem described above) in the circuit: VREF for bank 8 is not connected, at first I thought this wouldn't be a problem because all inputs that use the SSTL 18 CLASS I i/o standard are connected to bank 7 of which the VREF pin is connected. The DDR2 CLK is connected to bank 8 and I realized that the DDR2 controller IP uses the input buffer to read back the clock to compensate for delays (MIMIC path), so VREF for this bank should also be connected. I think this would explain the initialization failure.. Now I'll just have to wait for the boardrevision to come in. I'll post a confirmation when I've confirmed that this was the problem. Cheers, Olaf
