SCroi1
6 years agoHow to store user data necessary on the next power up
Hi, I have a MAX10 / NIOS II system with "Single Uncompressed image with memory initialization" configuration. During run time the system stores some data (512 bytes) that are needed at the next bo...
EricMunYew_C_Intel
6 years agoHi, Sorin
Do you mean you want to retain the data value of a variable in UFM flash when you power up again ? Normally the data value will be initialized to its initial value when you do power up again. The previous data will be gone.
Eric
