18 years agoHow to realize the pipeline in mixed operation of the divider or multiplication?
If I want to calculate the following function: f = (x * y + a) / z + b; there is five input variables and they may be changed at every clock. If use combinational logic to synthsize it...
18 years ago1) Whether one multiplication or division operation can be done in one clock?
The multiplication or division operation is not register based operation, they are combination logic operation, the clock you used just clock the operation result to a register. The following code has been validated when the clock is running at 10Mhz. ENTITY Y_BOX_cell IS PORT (clk: in std_logic; k: in std_logic_vector (15 downto 0) b: in std_logic_vector (15 downto 0); x: in std_logic_vector (15 downto 0); result: out std_logic_vector (15 DOWNTO 0); END Y_BOX_cell; ARCHITECTURE rtl OF Y_BOX_cell IS signal b_int,x_int,x_int1 : signed (15 downto 0); signal k_int : signed (15 downto 0); signal pdt_int : signed (31 downto 0); BEGIN Process(clk) Begin if clk'event and clk='1' then k_int <= signed (k); b_int <= signed (b); x_int <= signed (x); x_int1 <= x_int - b_int; pdt_int <= k_int * x_int1; result <= std_logic_vector(pdt_int(31)& pdt_int(27 downto 13) end if; end process; END rtl;
