18 years agoHow to realize the pipeline in mixed operation of the divider or multiplication?
If I want to calculate the following function: f = (x * y + a) / z + b; there is five input variables and they may be changed at every clock. If use combinational logic to synthsize it...
18 years agoI don't see your example exactly related to the question. It is using different clocks and likely to cause an unclear timing situation while sotusotu had a straightforward synchronous design as it should be. For longer delays (if needed at all), RAM based FIFOs instead of registers could be used, but with a single clock if ever possible.
Furthermore I think your delay examples are not corresponding to typical todays FPGA speed, they rather apply to last millenium types. As said, hardware multipliers can be used preferably.
