lambert_yu
Contributor
1 month agoHow to manual control the E-Tile transceiver's CDR mode of agilex 7
Hi, fpga chip : AGFB014R24B2E3VNL Issue : rx_set_locktodat and rx_set_locktoref doesn't present in E-Tile's Transceiver's CDR, and I didn't found the related avalon register to control this p...
- 1 month ago
Hi Lambert,
Yes, your understanding is correct. There is no workaround to control CDR in E-Tile. You may explore Agilex 5 GTS XCVR which support the rx_set_locktoref control. Thank you.
Himanshu_Varia
4 days agoIn Agilex7 F tile XCVR, can we use cdr freeze for BASIC configuration?
CheepinC_altera
4 days agoHi,
For your information, you cannot use the CDR free in Basic mode. CDR freeze is a GPON-specific feature in the F-Tile PMA/FEC Direct PHY IP. There is no documentation showing it is supported under a BASIC FGT PMA configuration. Thank you.
