rMa1
5 years agohow to integrate SG-DMA into the PCIe Hard IP core with AVMM interface
My design is using PCIe Hard IP core with AVMM-DMA interface, but the DMA descriptor length is limited lower than 128, I want to use 256 or larger than 256, how should I do?
Modular scatter-gathe...
- 5 years ago
Yes, the descriptor controller supports up to 128 descriptors, and this is unable to change to a larger number. Regarding to the modular SG-DMA, this is not necessary to use NIOS to configure. You can use any of the AVMM interfaces to configure the modular SG-DMA, for example, PCIe BAR.
SengKok_L_Intel
5 years agoIf further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
