11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- When creating a new component in QSYS, I'm having trouble guessing which group needs to be selected. --- Quote End --- That is not quite how creating a Qsys component works. You first have to determine *if* the bus interface used by your component is compatible with the Avalon-MM specification, i.e., whether its use of the address, read, write, and data correspond to the Avalon-MM use of those signal names. If it does not, then you have to create bridge logic that maps the transactions. That bridge might incorporate a FIFO (to handle bursts or latency). So my first question is, do you have a simulation for your VGA bus interface and your camera controller? If not, you should really write one :) Cheers, Dave
