11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- Method 1 is fine except that JTAG is still in there --- Quote End --- No its not. Look at the file qsys_system_sdram.v, it is *ONLY* the SDRAM controller component. --- Quote Start --- and the address size is only 13bit which seems way too short for 8Mb. Also the ram size hasn't been changed. The column and row values may also be wrong. --- Quote End --- That would be the "Ignore the fact that the DE0 may have different SDRAM". If you edit the SDRAM controller parameters to match those on the DE0 and then "Generate" the system, the generated .v file will have the parameters you need. --- Quote Start --- 1. For WRAPPER GENERATION METHOD# 2, why remove the clock? Why not leave the clock and SDRAM and just remove the JTAG component? --- Quote End --- Now you are starting to see the possibilities :) Cheers, Dave
