Knug
Contributor
5 years agoHow to handle properly pfl_flash_access_granted & pfl_flash_access_request signals ?
Hi @YuanLi_S_Intel
How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals if PFL uses both Flash Programming + FPGA Configuration mode
Looked at the PFL doc :
https...
JohnT_Altera
5 years agoHi Kevin,
What are your views wrt the counter I added ?
If the user does not program the flash and delays this passing the time when pfl_nreset goes back high, the system will fail to configure the FPGA.
I suspect that the PFL is performing something that cause the system will fail to configure the FPGA. Will need to monitor all the signal to understand what is actually happening.
