14 years agohow to efficiently drive async SRAM?
What's a good way to use async SRAM? I'm working on a Nios II system for a legacy hardware (Cyclone II) which has fast external asychronous SRAM. In fact two IS61LV51216 chips (512k*16, 8ns) in...
14 years agoThanks,
While being too impatient (:-P) I already started writing my own controller, as an Avalon slave. The pity with that is I can't even use the tristate bridge any more, since it seems not passing waitrequest. This is bad for the other chip on the external bus, instead of just attaching another tristate slave component I'll have to write that part by myself, too. For I test, I only implemented reading by rather directly passing signals. It *almost* works with zero waitstates. Only some disturbance on the LCD screen, which is a continuously reading bus master. :unsure: So you're right, I need a leadoff cycle, but by pipelining the read I will still be able to read one word per clock. I wonder if it would be helpful to make it a bursting controller. Is a leadof cycle enough penalty to make this a net win? The fixed read and write cycles are suboptimal, don't give enough control. For example, reading works without a "setup time" cycle, but writing doesn't. However this can't be independently configured. So far, I still stand to say that Altera supports async SRAMs not well... Jörg
