vdpavel
5 years agoHow to compile 2 PCIe instances in one project
Hi.
I need to use 2 PCIe controllers in one project. One of them for slow speed periphery like SPI and using Gen2x4 128bit 125MHz . Second one Gen3x8 256bit 250MHz. I create 2 qsys each with its ow...
Deshi_Intel
5 years agoHi Pavel,
Intel engineering team is still debugging the issue.
As a workaround, would you be able to use older Quartus version like v20.3 Pro for your project development while Intel continue to work on the fix for v21.1 ?
- We found out older Quartus version is not impacted by this issue and it only affect v21.1
dlim
- vdpavel5 years ago
Hi dlim,
Checked v20.3 is really not impacted by this issue.
Working on version 20.3 and waiting for new one.
Pavel
