How to chose our PCIe implemenation solutions, Avalon-MM or Avalon-ST?
AN855 is old 8 targetting to Quartus 18), but AN456 is much older. This should answer your question which to choose.
.par design archives are not regularly associated with Quartus, but cam be easily opened in Quartus. Start Quartus Prime Pro, go to open project, select respective .par file.
Recent Quartus PCIe IP has major changes to Quartus 18. I remember that it was suggested in some cases to rebuild it from the scratch instead of just upgrading it. But it seems that the design example still compiles in recent versions.
Hi FvM,
Thanks for you reply. We prefered to an855 at the beginning. We switched to learn an456 because we can't open the ref-design of an855.
Maybe, there are multiple versions QDP in our computer, this may cause our issue. We'll check carefully.
- Wincent_Altera1 year ago
Hi Minzhi,
First, thanks Fvm for help to reply on the previous reply.
Minzhi, another method for you to get PCIe reference design is through Quartus IP catalog
you may refer to below step for cyclone10/arria 10 device
https://www.intel.com/content/www/us/en/docs/programmable/683647/18-0/generating-the-design-68524.html
Let me know if you still cannot get it.
Regards,Wincent_Intel
- MinzhiWang1 year ago
Hi wchiah,
You know, my object device is Cyclone 10 GX, and also we have Cycone 10 GX development kit in hands. So when we generate example design, the target dev-kit still is required to chose Arria 10's kit?
BTW, our Quartus Prime Pro version is 23.4
Hi Minzhi,
Yes, I am aware that your devkit is Cyclone 10. You may select Cyclone10 devkit when generate the design.Inside it , you can choose the interface type as AVST and HIP mode speed.
Let me know if you still unable to get it.
