mifa's avatar
mifa
7 years ago
How to add Intel IP to Custom IP (hw.tcl)?
I am creating an IP with a bunch of Verilog files. In some of that verilog files I would like to use Intel IPs like ALT_IOBUF, ALTCLKCTRL or a FIFO.
If I start the simulation with the generated simulation script then the IPs were not found.
How to add those IPs to the _hw.tcl?
  • mifa's avatar
    mifa
    I don't know how that should help me. Can you please give me an example? In my understanding it is only about a selection of files, but how to add the IP.
    By the way, I fixed ALT_IOBUF. The synthesis was ok with it, but for simulation it has to be written lowercase "alt_iobuf".
    However, altclkctrl is inserted automatically during synthesis, but not for simulation. If I create a megafunction IP, then I dont know how to add it. The same thing with the FIFO.
    I tried to add the .sip, but that file is only copied which does not help the simulator.
  • KennyT_altera's avatar
    KennyT_altera
    Have you read the document on the call back feature? There is a posted example code there that you follow. Let me know if you don't understand how to use the feature.
  • mifa's avatar
    mifa
    Unfortunately, that example you gave me only showed how to add some .v or .sv files.
    I need a example for a structure like that:
    • top_file.v
      • file_a.v
      • file_b.v
      • ALTCLKCTRL (what I have to add?)
      • file_c.v
        • file_cc.v
        • Altera DC_FIFO_IP (what I have to add?)
    Adding the verilog files is clear, but what to do with the IPs? Is there a way to add .qsys or _hw.tcl?
    Workaround ALTCLKCTRL: Fortunately, the synthesis creates the clock switch by itself. However for simulation, I had to make a extra simulation file, because it was not found there.
    I think that way is still not best-practice.
