14 years agohow to access the on-chip fifo with my logic module for ST interface
I add a on-chip fifo in Qsys(see the attached figure), one interface is Avalon MM for nios2 access,and another interface is ST source for my logic . and the ST source's signals : ...
14 years agoI have tested the on-chip fifo ,with avalon mm write port and st read port
when I assert the ready high for st read port,the write data to avalon mm port will go through the st port, and the valid signal keep low(I use it to trigger a vhdl module with its rising edge,but not active ),why? thanks for your help!
