SrLam9
8 years agoHow does the Remote Update IP work?
Hi am trying to implement the Remote update IP core into my Arria 10 system with an EPCQ512. I want to have an application and factory configuration to fall back on. I am configuring the Remote updat...
Nooraini_Y_Intel
7 years agoHi SrLam9,
I have attached an example project design I just tested today on Arria 10 dev kit which works. You can refer to the rsu_cb.vhd which I wrote the parameters to read reconfiguration status register and write the AnF, disable watchdog timer and application image boot address. After power up the board (of course EPCQL was programmed with a .jic before), when I check using SignalTap to read the reconfiguration status register, I can observe the data_out[31..0] show 00000. You can try to check the rsu_cb.vhd and compare with yours.
Nooraini
