16 years agoHow does altlvds make bit alignment?
Hi, I'm currently using Cyclone III and trying to deserialize an LVDS data. It has 5 channel and 7bit data. 75MHz clock, deserialize factor is 7. I would like to ask a question. ...
14 years agoWhen in doubt, simulate. Modelsim will be able to answer your questions.
Put in a serial bit stream at the data rate you want to deserialize, or instantiate an altlvds_tx to generate the serial data. Cheers, Dave
