bralston7
3 years agoHow do you configure the pcie root port on the Stratix 10 to allow the HPS to map an I/O BAR?
I need help configuring the pcie root port on the Stratix 10 to allow the HPS to map an I/O BAR?. I started out with the Rocketboards Pcie example (https://www.rocketboards.org/foswiki/Projects/Strat...
bralston7
3 years agoWincent, you may close this issue. I believe I have been convinced by someone else at Intel that an IO bar is NOT required for my device, and that the driver has legacy firmware that asks for one, but doesn't necessarily need it. I've still got a PCIe-related driver problem, but its likely not because I need an IO bar. Thanks for your help.
-Ben
