bralston7
3 years agoHow do you configure the pcie root port on the Stratix 10 to allow the HPS to map an I/O BAR?
I need help configuring the pcie root port on the Stratix 10 to allow the HPS to map an I/O BAR?. I started out with the Rocketboards Pcie example (https://www.rocketboards.org/foswiki/Projects/Strat...
Wincent_Altera
3 years agoHi,
the IO Space enable is at bit[0] of command register.
Can you please try it out and see if you are able to do that ?
Wincent_Intel
bralston7
3 years agoSorry, I cannot see where I could possibly do that in Platform designer. I can't find anything resembling 'command register' on the PCIe IP settings
Did you look at my screenshot? Could you show me a screenshot of what you are looking at?
- Wincent_Altera3 years ago
Please ignore my previous message as different version of quartus and different design might have different approach.
I share the IO Space enable is at bit[0] of command register to you.
Is it answering your question ?
Regards,Wincent_Intel
